tyres scrubbing on springs
m193twa
Post by m193twa »
my tres are scrubbing on my springs. they are 195's does anyone no what size spacer i need to stop them scrubbing?
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
It depends how wide they are and what the wheel offset is...
carmadaaron
Post by carmadaaron »
its sounds like ur offset is wrong rather than the tyre .....
SpikeyG40
Moderator
Post by SpikeyG40 »
don't get me started on the scrubbing! i'm running a 3mm spacer on the rear of mine on 195 tyres (6.5" wide rim) n this brings the tyre out just a bit, if i were u i would go a bit wider! is it on both sides and is it both front and back?
lord_sharpy
spacer
Post by lord_sharpy »
had the same problem with mine, im running 10mm spacers, make sure you get some longer wheel nuts though and that you have about 6ish turns on the nut.
