heater fan
lord_sharpy
heater fan
my heater fan only goes on speed 3 and makes a bit of a screeching noise, only started doing it today in the freezing cold. is it easy to get to to lubricate doesnt turn on speed 1 or 2!
ste mk1lx
Re: heater fan
the resistor pack on the side of the heater motor is at fault easy enough to replacelord_sharpy wrote:my heater fan only goes on speed 3 doesnt turn on speed 1 or 2!
Tahrey1043
Steve_O
Re: heater fan
Yeah, i've had this problem before too. The resistor pack is basically a ceramic shaft with resistive wire wrapped around it. I did actually repair mine with a bit of solder where it burnt out, but a new one is probably peanuts, or free from a scrappy!!ste mk1lx wrote:the resistor pack on the side of the heater motor is at fault easy enough to replacelord_sharpy wrote:my heater fan only goes on speed 3 doesnt turn on speed 1 or 2!
The reason it still works on full speed is because it bypasses the resistor pack altogether, and just puts full power through to the fan motor.
If you take your scuttle tray out, the resistor pack should be fairly obvious!!
hardhitter
- Moderator
Gareth_GT_Hatch
I have had this problem (the screeching), and my dad solved it! Do not fear, don't replace anything. Simply drill a 20mm hole through the top of the fan housing, give it a good spray of WD40 (it will smell a little while afterwards in the car, but it soon disappears). Once the squeeking has stopped, simply plug the hole with a 20mm blank plug.
Sorted!
(PS. I've also had/have some leaves in the system. Just pick them out from the gap in the side of the fan housing, and/or when they blow up through the heat shafts and come to the fan grille, just pick them out with pliers etc.)
Sorted!
GroovyCarrot
- Sponsor
I was just about to post exactly the same problem as this
Already replaced the fan once after the old one drove me nuts with it's squeaking, now the replacement has started squeaking and only works on full speed. Glad to hear it's a fairly simple repair, because those fans are a right bugger to get out..
Tahrey1043
GroovyCarrot
- Sponsor
lord_sharpy
amstrange1
hardhitter
- Moderator
I think the best way to stop is squeeling is to remove the housing and take it apart so you can see where it's catching. Then lubricate with some proper grease that will last.
Oh and the resistor pack has a silver inline thermal fuse underneath it. Thats between no's 1 and 2, de-solder and remove it and put a piece of wire in place. Then it will always work on all three speeds without going again.
amstrange1
Ja, and potentially cause a fire if it gets too hot. You muppet Barningfield!hardhitter wrote:Oh and the resistor pack has a silver inline thermal fuse underneath it. Thats between no's 1 and 2, de-solder and remove it and put a piece of wire in place. Then it will always work on all three speeds without going again.
