The left window now goes up and down, but does not continue to go right down or up as it did before. It will only move if the button is held down basically.
And, although the motor is working in the drivers window, the window is not moving at all! It remains closed whether I press the button for up or down.
So, somehow, the flat battery condition has wiped the window program!!!
Anyone know how to restore the original programmed window settings
