6N2 - Retro-fitting OEM fogs
Posted: Tue May 27, 2003 8:24 pm
firstly you will need some parts which i got from martyn at vag parts
-new light switch with front for position
-2x foglights
-6x screws
-6x washers
-6x little square plastic clip kinda jobbers
-2x grills ( i suggest getting the gti centre grill too)
TOOLS NEEDED
phillips screwdriver
smallish flat screwdriver
torx25 (long and thin)
torx 20 (optional)
ok im sat here with a load of boxes now what???
firstly you need to swap the 2 light switch which is as simple as removing the original switch and unplugging it then plugging in the new switch and refitting
a full explanation of the removal can be found here http://www.tigerstyle.co.uk/poloforum/v ... .php?t=341 (cheers mole)
now to the outside
well its logical to get some power to the fogs before you fit them but THIS IS NOT NEEDED all the wireing is already there ( as i found after spending 20 min making a loom
all you need to know is where to look so firstly you need to remove the existing side grills by finding the hiddedn screw (phillips)
in this photo ive already fitted the fogs but the screw is in the same place
then pull on it both forewards and to the side and the grill will come out
then you are left with this:
to which you have to fit the 6 sqare plastic clips (grey) (ive already fitted them) they go in the holes with the square "border" and just push in. you want 3 per side. this isnt part of the wireing but you might as well do it so you dont loose the clips
now to find the wire.
have a good look inside the hole and look for a cable (with a black sheilding) that is plugged in. here are some pics to help you find it
this is one of the clips that holds the blank that the wire should be plugged into and the large sliber part with the treaded piece 'hanging' down is the chassis leg
now you need to give it a good yank as you dont need the blank and its not easy to unplug it
here you can see the blank that mine were plugged into. next you have to unplug the cable from the blank and plug it into the fog light
now we get to fit the lights them selfs, after checking that theres a bulb. they simply attach with the screws supplied but dont forget the washer.
the screws go into the clips that you fitted into the holes before
then all thats left is to check that you have the conenction properly attached and the screws good and firm so that the light unit doesnt move. then fit the grill as you removed it and your ment to reuse the same screw however i didnt use the phillips screws
i used some of the screws that are used in the dash that are torx 20 and have a larger head so that they dont fall out and get lost as they are the same size as the gap in the grill that the head fits through (its a tight fit thou so it will scuff the plastic a little). Also with them being torx it makes it harder if some toe rag wants to steal your lights.
now repeat for the other side and do a quick test so you can admire your handy work
you may have to adjust them so that you dont blind oncoming traffic. this is accomplished by using a long torx 25 and threading it through the little hole below the lens as so:
now your ready for a little trip out so you can show off
here you can see the difference that they have made to my car as the before photos are with no grills and some el cheapo fogs
ahh steelies
now for the after shots
if you have any questions then please feel free to ask as if all your wireing is not there then i will explain how to make a loow (on my car everything was there including the relays etc)
-2x foglights
-6x screws
-6x washers
TOOLS NEEDED
torx 20 (optional)
now to the outside
ahh steelies
