I was going on the motorway this morning and the oil light came on.
My 1.9 TDI is only 8 months/10.5k miles old.
I have checked the oil and it is low but I cant see any leaks.
Has anyone else had any problems?
Do diesel engines drink alot of oil generally. (My first diesel )
Si
Any Polo 9N TDI owners
Re: Any Polo 9N TDI owners
They tend to drink a bit for the first ten thousand miles, mine did exactly the same thing, oil light beeped and flashed on when I was cruising on the motorway. Thought me to check my Oil reguarlyVdubber wrote:I was going on the motorway this morning and the oil light came on.
Si
Don't worry about it the the PD tdi's are known for it.
Des
- bstardchild
- Moderator
Check it more often - every week/month at a minimum - it's the only thing that keeps the moving parts apart!!Vdubber wrote:I was going on the motorway this morning and the oil light came on.
Good move - at least you know it's using it slowly rather than a cracked sumpVdubber wrote:I have checked the oil and it is low but I cant see any leaks.
Yep - more when new (during the bedding in process) - less in middle age (when all the tolerances are at their best) - then lots when old and leggy - (in fact I think the chose engine oil over the other stuff you put in the tank - maybe it tastes better )Vdubber wrote:Do diesel engines drink alot of oil generally. (My first diesel )
I have never topped up a car with oil in my 8 years of driving.
Even though I have checked the level every now and again. I just wasnt expecting a newer car to need it.
Si
I wasnt sure which oil to get because my car is on long life services and the oil is different. So I just got a top up bottle from the nearest VW.Make sure you have the right oil, though. Just pointing out the obvious, but you do say it's your first diesel.
Deek.
Si
