new brakes
Posted: Tue Jan 18, 2005 8:26 pm
by lord_sharpy
ive got my g40 callipers, and im just in the process of cleaning etc. im gunna put on the brembo discs and pagid tq pads from GSF, what do you guys reckon to this? also what is better for not alot more money like grooved discs etc?
also whats your opinion on braided hoses? worth it or not?
Posted: Tue Jan 18, 2005 8:59 pm
by hayesey
braided hoses are definately worth it. grooved &/or drilled discs are just for show more than anything else. All the grooves & holes do is evacuate brake dust & I doubt you'd notice the difference between similar discs - one without grooves or holes & one with grooves & holes.
they're also good for racing cars which use very soft brake pads which produce a lot of dust, but get changed after every race!
hoses
Posted: Tue Jan 18, 2005 10:32 pm
by lord_sharpy
anyone got a set of braided hoses knocking around or just a couple?
Posted: Tue Jan 18, 2005 10:42 pm
by Karl_CLCoupe
Try
Awesome-GTi. Quite a reasonable price I reckon.
Karl.
Posted: Wed Jan 19, 2005 12:30 am
by Krupa
Or Pitstop Developments, their braided hose kits are about £40.
Braided hoses are worth it definately, but when I up the size of my discs again I won't be getting grooved discs. I will however be buying Greenstuff pads again, as they produce next to no dust and I'm lazy.
Posted: Wed Jan 19, 2005 2:01 am
by DelG40
I'm also under the knowledge that grooved discs help displace heat too, no?
Posted: Wed Jan 19, 2005 8:47 am
by hayesey
no, grooved discs don't do anything to dissipate heat, only brake dust.
vented discs help dissipate heat better but he's already getting those since he's got G40 calipers.
Posted: Wed Jan 19, 2005 9:47 am
by lord_sharpy
i think il have to order a set of hoses then along with discs and pads at the end of the month.
Posted: Wed Jan 19, 2005 9:59 am
by Krupa
I'm told drilled discs help dissipate heat better, but grooves do nothing for cooling.
Tests by Porsche or something, hence Porsches having drilled not grooved discs.
I might look into Zimmerman drilled discs when I change, but grooves don't seem to do much.
Posted: Wed Jan 19, 2005 10:30 am
by hardhitter
Yes, the greenstuff pads produce little dust and it's easier to clean your wheels. The down side is they are poor brake pads compared to others. I'm waiting for a set of Raicam pads off pitstop which are supposed to be excellent according to people who have used them.
Posted: Wed Jan 19, 2005 10:44 am
by genesisGT
I have Zimmerman cross drilled and vented disks with pagid fast road pads and a standard M/C and rear brakes. I just fitted new rubber pipes when I converted, but now wish a had fitted braided ones!
That set up Brakes very nicely, but push too hard and they just lock up.
The pads produce quite alot of dust (mabe my driving) but it wipes of easily enough!
So a would recommend the above but with the braded hoses and posibly greenstuff pads as a hear thery are very good (and produce less dust).
Posted: Wed Jan 19, 2005 1:58 pm
by peteg40
remember to check drilled discs every now and again as sam baldwins has cracks round every hole!
Posted: Wed Jan 19, 2005 5:48 pm
by Krupa
I'd be interested to try standard discs and pads first of all when I next upgrade (planning on 256mm at some point) then compare these to performance pads and see what's best.
Can't really complain about the Greenstuff pads personally, they're not bad. Are there any low-dust pads that are better performance wise?
Posted: Wed Jan 19, 2005 7:35 pm
by genesisGT
Will do! But the polo only has an AAU engine fitted (my garage floor has the GT) just now so a dont think the disks are getting to much stress braking from a max of 90ish.
Posted: Wed Jan 19, 2005 8:27 pm
by pete69zx
genesisGT wrote:the polo only has an AAU engine fitted (my garage floor has the GT) just now so a dont think the disks are getting to much stress braking from a max of 90ish.
Tell me about it
