Coupe S suspension problems.
Chat about your MKI or MKII Polo (86 and 86F)
Rattyuk
Post by Rattyuk »
my mate has just bought a 89 mk2 polo coupe s with 15 bbs wheels on it, pretty sure there the standard goof gti wheels. any way it is rubbing the arches really badly. apparently the car has been lowered 20mm on g40 springs, but they may just be cut down stock springs.
my question is can you get hold of just uprated dampeners because the car is really bouncy and i think it needs stiffening up allot so as to stop the rubbing. or do you need new springs too?. the rubbing happens in a straight line too when you brake hard.
its really shreaded the outside of the tyres :(
any help would be much appreciated
Ratty
rustypolo
Post by rustypolo »
if your m8s polo is bouncing around that much i would tell him to check his shocks cos mine used to bounce until i change them now its like its on tracks german swedish do the best shocks
polokris
Post by polokris »
if they are "cut" springs... GET SHOT OF THEM!! dangerous!!
best bet is to get the dampers, mine was bouncing around alot, they were gon... u could c the oil..... :?
so i changed them and it handles like a go kart now! (lowered 40mm too)
Rattyuk
Post by Rattyuk »
thanks for all the replys :)
where would the best place to get uprated shocks/dampeners from also what would you reccommend?
thanks
Ratty
GroovyCarrot
Sponsor
Post by GroovyCarrot »
If the springs are actually G40 springs then they should be ok on standard dampers, but definately make sure they're in good condition. If they're cut springs then get rid ASAP.
You may want to look into getting the arches rolled if the tyres are rubbing.. even if it is just because the suspension is a bit soggy atm, they'll still catch any time you go over a bump or have any kind of load in the car, and it's seriously bad for the tyres. You don't really want bits of tread flying off or the sidewalls blowing out at speed, not fun :? 15" wheels are always going to be a bit of a pain though, it's about the limit of what you can squeeze into the arches.
Rattyuk
Post by Rattyuk »
yeh the 15"s are preety big although if you spy this pic they have plently clerance....
doesnt rub driving along the flat or steering when driving sensibly, only rubs when braking hard and hitting bumps, but its proper shreading the sidewalls :(
thinking some gas shocks from eurocarparts would solve it maybe? that or maybe load the piston up with some bumpstops?
Ratty
ZOMBIE
Post by ZOMBIE »
Those tyres are definately the wrong profile for your car mate! get some 40 or 45s and then deck it on proper 40 mm springs! :)
also the fact that the tyres are so meaty may be aking the ride bouncy!?
GroovyCarrot
Sponsor
Yeah, those tyres are definately too big. If you don't want to modify the arches (which I'd really advise running 15's), you need a low profile tyre without too much width to it. Even if the tyres are only scrubbing over bumps and under braking, it's still quite dangerous.. think how much wear those sidewalls are taking :?
On another note, nice car :D Looks pretty mint. Out of interest, whereabouts are you? If you're around the herts/essex border you can't be far away from me ;)
Rattyuk
Post by Rattyuk »
GroovyCarrot wrote:Yeah, those tyres are definately too big. If you don't want to modify the arches (which I'd really advise running 15's), you need a low profile tyre without too much width to it. Even if the tyres are only scrubbing over bumps and under braking, it's still quite dangerous.. think how much wear those sidewalls are taking :?
hmm tyres arnt all that cheap :(
only down in stortford btw. i roll round in a 91 golf gti, 93 polo coupe (1.3) and a 71 bug,
mates just got this car and were trying to sort it on the cheap really. so just trying to stiffen it all up. tyres arnt really causing the body roll so think the shocks are proper shot. any body advise a good company for shocks? eurocarparts seem the only place i can find with gas ones.
k4lps
Post by k4lps »
Rattyuk wrote:yeh the 15"s are preety big although if you spy this pic they have plently clerance....
Ratty
you have the wrong size tires there tires that would fit a golf you need a smaller profile
example 175/70/13 from a golf would need changeing to 175/60
i have the above and they rubbed on the inner plasitc arch and on full lock it dont do it much now cos the plastics had warn away
k4lps
Post by k4lps »
http://www.blackcircles.com/?c1=WebFind ... re&kw=tire
for a tire size calculator
http://www.polo-gt.co.ukyou'll find it under 'Mechanical and Tuning'
polokris
Post by polokris »
get rid of the balloonish tyres, and it will solve most probs....
i got dampers from GSF... they are really good, and only a coupl of quid! :D
GroovyCarrot
Sponsor
Yeah, I know only too well how expensive tyres are.. but really, those are just too big for the car. If you're doing it on the cheap then check eBay for part worn tyres, if you're persistent enough you can find some barely used tyres for very little money.
GSF sell cheap shocks that seem to do the trick, sorted my front end roll no problem.. just got to get the back done now, I've had several friends commenting on how it looks like I'm driving a waterbed from behind :oops: As far as I know the G40 used the same length shocks as other mk3's so you shouldn't need to worry about getting shortened shocks or anything.
Rattyuk
Post by Rattyuk »
right just got another look at the polio and it has 14"s on it.
the tyre size are 185 60 R14 so profile seems preety big.
Ratty
GroovyCarrot
Sponsor
Yeah, my 185/60's rubbed pretty bad, and that was on 13" wheels, so it's definately too much on 14"s. I think really you're looking at 50 profile or below, and possibly go down to 175 or 165 section.
