Glovebox light
Glovebox light
Do ANY new Polos have a glovebox light? All the ones I have seen haven't, I will add one if not, but is this easy? There is like a blank, black plastic plate, but it is facing the front towards the seat?
Just wondered, does anyone have a picture of their glovebox? (empty) as I remember seeing a black blank kind of plastic bit at the top right hand comer of the glovey when it was open, is that the space for it?
If not I have a couple of ideas of lights that may fit.
I mean it wouldn't be hard to hook a bulb up, but the problem is, it needs a switch so it will turn off when it's shut, or it will just get too hot and the bulb will burn out too quickly!
I know it sounds silly, but it's so important at night and is one of those great things to have
This is the space
I just to have a VW BUG and add a light to the gloVe box.
I used a Door alarm clip for turning on or off the light
So when the door is closed the Clip is pressure and when you open it make contact and turn the light on
Is not that hard.
When I put mine I will show you. I really need it to.
Is not that hard.
