induction kits
nothin2lose
I got an 57i induction kit when i first got the car and i really wanted to keep the air box as it made the engine look tidy, but i cudnt work out how to keep the air box and fit the k&n, so i got rid of it and now seeing these pics i want to put the air box back on and somehow fit the k&n but i aint got a bloomin clue
AKs_SlickPolo
if you go to ripspeed/halfords they sell a replica/ripspeed version of the bmc. Its about £60 iirc, looks almost the same. As it has a direct air supply, it will pull in less hot air. I currently have a K&N on a 1.4. It sounds decent and gives you a sucking noise when the air is drawn in. Ive personally noticed that the engine is a bit more responsive, but dont expect to get a huge performance boost, there is a little more on high end speeds though.
rishisisodia
polopowah
- Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
yo materishisisodia wrote:wow, i have a 1.4 16v and a SHYT wage lol, will the ripspeed one from halfords give me the sucking noise? i thought only dump valves give thatdont u need a turbo 4 that? x x x
even the k&n induction kit gives a nice sucking noise, quite loud actually and sounds abit turbo-ish hehe, not sure what other makes of filters make this noice but i should imagine most cone and cylinder filters would do.
-Ben-
nothin2lose
AKs_SlickPolo
K&N makes the sucking sound after you change gear and tap the accelerator, mines loud TBH, it doesnt sound like a dump valve, but does sound rather nice
Na the ripspeed one i aint sure, but its called a Ripspeed Carbon intake kit...its a universal jobbie, but i reckon the bmc is too.
cough*~#i might have my k&n for an mk4 for sale#~*cough
@ Daveo - pics of what mate? a k&n on a mk4?
AKs_SlickPolo
A dump valve noise is much more deeper, if your looking to imitate one of these with a air filter then NO this wont do it. If u REALLY need this noise then i would suggest buying one of those speaker things that have the dump valve noise pre-recorded, which plays
you cant get a faker dump valve than this!
rishisisodia
