Rolling road result
LregG
Rolling road result
Post by LregG »
189 bhp at 6737, 162 lb/ft at around 4350 rpm
Not bad for 1272cc eh??
Here's a video of my car on the rollers (power run at 1:35)
video
Tahrey1043
Post by Tahrey1043 »
gotta love that torque curve (so long as you like high revvin')
not much below 3000, but ok for trotting round town..... 3500 onwards, pretty much flat, like a TT or something but even wider range, storming :D
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
its got about the same torque as mine at 2500rpm (well mines got a bit more) but its all good... 8)
LregG
Post by LregG »
Tahrey1043 wrote:gotta love that torque curve (so long as you like high revvin')
Err, right?? If it had 162 lb/ft at 1000rpm, i'd never get it to pull away without spinning up mate and why do you need to like high revving?? That torque curve is near on text book!!
Tahrey1043
*peers more closely at scan*
lol ok, its actually more punchy torquewise at about 2250 than mine is at 3000 :D (not saying much, i know, but its definately not short in the tugging department)
but all the same your peak power is above the revlimiter of a standard G, thats why its a good engine setup for a revpimp :)
that's not saying it won't pull like a god damn train through the entire sensible caning range, because it will (im sure you can confirm that, hehe) but as torque is divided up by the gearing, its the power you have to look for in a straight line fight rather than down the lanes.
PS if you had 162lbft at 1000rpm, couldn't you simply not give it full throttle at that point or slip the clutch a fair bit? I rare give the astra full throttle from the line without being quite careful with the clutch and the revs, as it spins the tyres up easily even with it's comparitively meagre output. I'll more often give it say 2/3rds, then bring on the full power quite quickly once it's rolling to avoid crazy spinnage/slippage.
(a good turbodiesel gives that amount of twist, at 1200, 1500 or so anyway if not exactly 1000, its all a matter of how you deal with it)
just sayin ;)
anyway, 189hp divided by 1.27 = double plus good
