I heard that the Formel E Engine is slightly different to other normal 1272cc polo engines:
"A high fuel efficiency model which did make production was Formal E (E for Economy), introduced in 1983. This used a high compression 1272 cc engine, longer gear ratios and an early stop-start ignition system (called 'SSA') that would cut the engine when idle for more than 2 seconds to save fuel whilst temporarily stopped in traffic, and re-start the engine on moving the gear lever to the left in neutral. The system could be disabled by means of a toggle switch below the light switch to enable the system."
Does this mean it generates more power compared to other standard 1272cc polo's, because its a High Compression Engine?
Also i hear from the previous owner that the top speed of this little car is well over a 100mph, Is this possible? I am unable to test myself because i dont have a license and the car isnt taxed or insured
Since being given the car well over 2 years ago
Any Advice or Comments Are Aprreciated.
