Buzby
Sponsor
Posts: 251 Joined: Wed Aug 10, 2005 8:16 pm
Post
by Buzby » Sun Jan 15, 2006 4:11 pm
I've got no light in the boot, but I came across a connector - 2pin and quite thin, underneath the trim in the boot on the drivers side. I've put the multimeter on it and it goes from 12v unlocked to 10v locked.. is this a connector for a boot light...
Buzby on Wed Aug 09, 2006 7:30 pm, edited 1 time in total.
dino
Sponsor
Posts: 3023 Joined: Wed Jun 08, 2005 11:59 am
Post
by dino » Sun Jan 15, 2006 6:58 pm
Not sure but i'd say it was the connector for it. That where mine is.
macemc86
Posts: 282 Joined: Mon Sep 26, 2005 9:38 am
Post
by macemc86 » Sun Jan 15, 2006 7:24 pm
very interesting..... i dont have a light either, could do with one though! lemme know how this works out.
GaryUK
Posts: 501 Joined: Tue Aug 10, 2004 12:54 pm
Post
by GaryUK » Sun Jan 15, 2006 7:28 pm
I've not a clue but
this thread might help.
vwclub.gr
Posts: 179 Joined: Sun Jan 02, 2005 3:33 pm
Post
by vwclub.gr » Sun Jan 15, 2006 7:30 pm
This is the one. Instead of installinh the OEM lamp which is very dim, try connecting a pc's cool cathode light. Much more light strength, and very beautifull.
M7
Posts: 658 Joined: Sun Jul 18, 2004 11:55 pm
Post
by M7 » Mon Jan 16, 2006 11:30 am
back in the days of when i thought neon lights were good i had one in my boot. just had it plugged onto the power cable to my amp and earth it.
worked fine and alot bright that a vw boot light
n3oNx
Posts: 202 Joined: Fri Apr 09, 2004 1:29 am
Post
by n3oNx » Mon Jan 16, 2006 4:37 pm
Buzby wrote: I've got no light in the boot, but I came across this connector - 2pin and quite thin, underneath the trim in the boot on the drivers side. I've put the multimeter on it and it goes from 12v unlocked to 10v locked.. is this a connector for a boot light...
pic...
Yes it's the connector for the boot light.
Buzby
Sponsor
Post
by Buzby » Mon Jan 16, 2006 6:17 pm
Thanks for the reply's ..Ill pick up a light from the dealers when I can, and let ya know ...
But why dont vw put a light on the end of the wire at the factory , how tight can ya get..
n3oNx
Post
by n3oNx » Mon Jan 16, 2006 6:24 pm
Mine didn't come even with a connector... I bouth my light for 10€ (+-6£) from my local dealer. Multiply that by thousands of cars and you'll see a global reduction in the cost of the cars.
Buzby
Sponsor
Post
by Buzby » Fri Jan 20, 2006 6:12 pm
Bought the light today plugged it in and ... it worked..
The part number is 6L0 947 415 and cost £5.50... for reference.
SiDaBa
Sponsor
Posts: 1494 Joined: Fri Jul 25, 2003 12:45 am
Post
by SiDaBa » Sat Jan 21, 2006 12:29 am
From SE spec (I think) or Sport Spec upwards you got a boot light which is why it's so strange you didn't have one buzby.
Those of you with specs lower than this there will be no wiring there for you, you'll have to find your own way of hooking it up.
Christmas decorations should have been taken down by now btw
only kidding
n3oNx
Post
by n3oNx » Sat Jan 21, 2006 12:41 am
SiDaBa wrote: From SE spec (I think) or Sport Spec upwards you got a boot light which is why it's so strange you didn't have one buzby.
only kidding
I've allready have one on my car (stock = no light). I went to my local audio dealer and he did it at the same time he was finishing my alarm install.
SiDaBa
Sponsor
Post
by SiDaBa » Sat Jan 21, 2006 4:13 pm
n3oNx wrote: SiDaBa wrote: From SE spec (I think) or Sport Spec upwards you got a boot light which is why it's so strange you didn't have one buzby.
only kidding
Yeah as i said - will have to find your own way of hooking it up.
Buzby
Sponsor
Post
by Buzby » Sat Jan 21, 2006 5:20 pm
The dealer (south hereford) said they have had a few polos come through without a boot light when there should be one fitted
inder
Posts: 1842 Joined: Sun Feb 27, 2005 8:37 pm
Post
by inder » Sun Jan 22, 2006 12:01 am
Buzby wrote: The dealer (south hereford) said they have had a few polos come through without a boot light when there should be one fitted
and they still charged you for the part
glad you rigged it up m8
