water gets on/in the central locking pump? i'm guessing it'll stop working?
how would i go about fixing this please.
thanks
What happens if...
Righty-o Haynes manual time !!
Fault finding page REF.19
Central Locking system inoperative or unsatisfactory in operation
Complete system failure
Blown Fuse
Faulty Relay
Broken or disconnected wiring or connections
Faulty Bi-pressure pump
Latch locks but will not unlock, or unlocks but will not lock
Broken or disconnected latch opersting rods or levers
Faulty Relay
Faulty bi-pressure pump
I wont bother with the rest coz it dont sound like it applies !
basically from that i would say Check the fuse is not blown !!
Check wiring around the locks, or where the water damage is !
Check the relays
and lastly the obvious one check the pump for damage or signs or fault
any help needed i can check the good ol haynes manual for ya on ways to fix or remove !!
HTH
Blown Fuse
Faulty Relay
Faulty Relay
Check the relays
HTH
yeah mine locked today, i got stuck outside the car and my friend got stuck inside. (door pins were held down)
turned the key as much as it would go and the windows came down (door pins stayed locked) and i jumped in, then drove around the corner and i could pull up the door pin suddenly.
the boot doesn't open at all nor does the petrol flap!
i duno how to take off the blue wire running to the central locking pump!?!
HEEEEEEEEEEEEEEEEEEEEEELP
