how do you get the indicator lights to stay on, (usa style)
tupac2makaveli71
not too sure if it is legal, but to switch between the two modes just connect pins 87 and 87a to the outer two terminals on an spdt switch (single pole double throw) and the inner one to the other end of the indicator wire.
tried this tonite an found out that the lights on the dash stay on with the indicators when used as daytime lights, to combat this problem another relay is needed to convert the polarity of the wires going to the dash lights
tupac2makaveli71
Re: re: diagram
You sure about that diagram?ximon wrote:aaah lol ive only just realised what you guys are after, the diagram above provide a small voltage to the lights which keeps the indicators half on when your side lights are on, it looks like your after indicators which are on normally and off when flashing, this is what your after ( the12volt style )
the main indicator supply wires are the wires from pins 3 and 7 from the indicator switch itself
fixed
should be right now 87 and 98a shouldnt of been connected
tx mr_toad!
tx mr_toad!
Get it from ebay
http://cgi.benl.ebay.be/US-Blinker-Stan ... dZViewItem
Just a simple module that you place between your indicator cable and indicator and you wire it onto the sidelight cable also.
5 minutes of work.
This is how it looks on FK Powerlooks:
I haven't been pulled over since i have them, but then again i live in belgium. But I don't think it would be a problem since the new Volvo's and BMW's also have a thingie like it. Just make sure they still flash properly.
5 minutes of work.
