first aid kit???
first aid kit???
I can remember someone saying that there is a place for a first aid kit. Where abouts is it? I have searched everywhere and cant find a good place for it! Any good ideas?
des_pd_ tdi
That is where I keep my fire extinguisher too! So either I move my fire extinguisher to another place or I "try" and find another place for my first aid kit! I like my fire extinguisher where it is though, it is just a nice fit and looks good there everyone always comments on it.
They should have made something on the other side for a first aid kit!
Nelson_Wilbury
- Moderator
des_pd_ tdi
My first aid kit is left (held by the rubber strap)..
there's just one problem....
there are these two strings that hold the "boot-lid". They each have a weight so that the string will always hang down...
It can happen that the weight of the string somehow gets caught/stuck in the rubber strap. Next time you open the boot the string and the weight will be torn apart
That happened to me.... a replacement strip costs more than £3.
Nelson_Wilbury
- Moderator
OK then. Just to confirm for people browsing this topic.
The strap in the boot to the left is to hold the first Aid kit, the strap under the slam panel (mine doesn't have it but I assume its a SE/Sport only thing again) is for the warning triangle.
However, I'm toying with a little idea which will mean you can put both items in the left hand side, just because I can!
Nelson_Wilbury
- Moderator
