[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Et....? - UK-POLOS.NET - THE VW Polo Forum
depends what size wheels you have too. you can have anything from 20 standard 38 on 14's and 25 upto standard on 15's if not too low.
I have et30 on 14's and it fills out the arches lovely, you dont want them sticking out past the widest part of the arches very much unless your gonna change them MOT time.
with 16's if you want to go really low its best to get an offest of between 35-38, so that the tyres sit nicely under the arch
if your not lowering past -50mm then i'd go for a lower offset to fill those arches.
