Polo Ravers,
I need help.
The boot light when opened does not come on , but the bulb is fine after checking with a battery.
So is there a fuse in the fuse box that might be burnt?
if so, which fuse!! because they are all numbered with pictures on the card, all of which none of them resemble a boot!!
Luggage Compartment Light Not working!!
- Sponsor
Re: Luggage Compartment Light Not working!!
the problem is with the mirco switch that inside the rear lock on the tailgate, has the rear wiper been leaking in the past ,if so it start to rust causing a poor connection , you have 2 choices , strip the swicth out the lock and try cleaning it or buy a replacement mirco switchmattyy wrote:Polo Ravers,
I need help.
cheer kenny
same problem..
yeah, i've got the same problem- i don't think its the fuse, as there is one fuse that controls the interior lights and boot compartment light (checked using haynes manual) so if your main interior light is working the fuse is fine. My boot light bulb is fine also it hasn't blown or corroded, but still fails to come on- so kenny15 must be right, i haven't checked the microswitch- where is this exactly? i don't think my rear wiper leaks either but there must be dodgy wiring going on somewhere in the boot- so i reckon we both have the same issue..doesn't seem like a big problem but its pretty annoying when its dark!
sorted
i sorted mine mate.
i took it to the garage and they WD-40 the latch on the tailgate, and kept playing with it, pushing it in an out.
in the end it started working because of a loose connection, so try that.
Mattyy
Mattyy
fuse numero 10 in the fuse box, 7.5 is the one you need ![Smile :)](./images/smilies/icon_smile.gif)
- lolhoward
- Platinum Member
Mines been playing up for ages. Sprayed mine too but only lasted a short while. Anybody know the part number of the switch for a mk5?
