Any Advice??
pootas
Any Advice??
Post by pootas »
I've just bought a 2000 Polo Gti with 45k on the clock... Since reading these forums I've learnt the Polo may not be as bulletproof as I thought it was so I've got a couple of questions and any advice would be appreciated:
1. If the car hasn't had the pedal box recall completed will VW still do it considering the car is now 6 yrs old?
2. The car is going to have a minor service by the dealer before I pick it up ie. Oil change etc... How long should I leave it before I get a major service ie Belts and Tensioners..(Should I just wait till it's done 60k)?
3. Are there any tips you can give me for checking the engine over for signs of wear specific to the Polo Gti?
4. What is the best induction kit/lowering springs for the car?
Thanks in advance....
ModifiedMadness
Sponsor
Re: Any Advice??
Post by ModifiedMadness »
As far as I know they should do, but by now I would imagine it's been done
My last service was 56k, it was near enough to 60 for me so I got them done with that, your next service will now be due at 55k, so I'd get it done then.
There isn't any that I know of, the engine is pretty much sound on them. The only weak spots are the pedal box and gear box.
For induction I'd say the BMC, I haven't got one myself but everybody raves about them, as for springs I'm not too sure.
Hope that helps mate, oh and welcome to the site and congrats on getting one :D
Si_GTi
Moderator
Re: Any Advice??
Post by Si_GTi »
ModifiedMadness wrote:For induction I'd say the BMC, I haven't got one myself but everybody raves about them, as for springs I'm not too sure.
BMC is great, makes an awesome noise and will give you plenty of smiles when you open the throttle up :wink:
pootas
Post by pootas »
Hmmmmmm The BMC Kit does seem to get a lot of praise but it just seems soooo expensive compared to the other induction kits from K&N and Pipercross.... I think I may just get a K&N panel filter for now until I decide which induction kit I'm gonna get plus it seems I need a seperate crank case breather pipe which insnt included in the BMC KIT...Toooo confusing for me.
Thanks for your advice so far guys it's much appreciated...
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Yes the BMC is expensive, but its certainly worth it. Keep a look out for any that come up lightly used ones for sale to save some cash. As for the crankcase breather, it really isnt that big a deal so long as you get one that fits.
pootas
Post by pootas »
Sounds like a good idea but I know I'm too impatient to wait!!!
Out of K&N, Powertec, Pipercross and Raid which induction kit would you rate. They all seem to contain the same amount of parts to me but has anybody found a one kit to be better than the others???
Si_GTi
Moderator
Post by Si_GTi »
pootas wrote:Out of K&N, Powertec, Pipercross and Raid which induction kit would you rate. They all seem to contain the same amount of parts to me but has anybody found a one kit to be better than the others???
What you need to consider is how much you can shield each kit from the heat in the engine bay. The Polo's airbox sits directly on top of the inlet manifold and so there is a lot of heat being produced when the engine is running. A good cold air feed only goes some of the way towards compensating for this issue.
The reason why the BMC induction kit is so popular is that the air filter is encased in a genuine carbon fibre housing to prevent hot air from being drawn in :)
i can post up a couple of pics if you like to show what I mean about the location of the airbox :)
BENNO
Post by BENNO »
WERES THE CHEAPEST PLACE UV FOUND THE BMC KIT?
Si_GTi
Moderator
Post by Si_GTi »
ON THE INTERNET :D
Shop around, try Demon Tweeks, Euro Car Parts, or just Google it to find best price :)
olop_chris
Sponsor
Post by olop_chris »
I got mine for £70 off a lad on club polo, keep your eye out and you'll have a bargain 8)
pootas
Post by pootas »
Most of the kits I've seen Pipercross, Raid, K&N etc have a connector to feed the Crankcase Breather Piper into....Does it make a diffence whether it connects onto this pipe or whether you put a seperate small filter on the breather pipe? Just a thought....
Also anyone tried these??
http://www.potn.co.uk/green-dynatwist.php
andrea
Re: Any Advice??
Post by andrea »
pootas wrote:2. The car is going to have a minor service by the dealer before I pick it up ie. Oil change etc... How long should I leave it before I get a major service ie Belts and Tensioners..(Should I just wait till it's done 60k)?
I've also got a 2000 GTI with 48000 on the clock.
I had my cambelts/tensioners and water pump changed last month and when i looked at the main cambelt it was really badly worn. I heard from a friend at VW that they are known to break early so i got mine done as piece of mind.
I have also just lowered my car on 50mm eibach springs. They are a good ride.
Hope this helps xxx
pootas
Post by pootas »
Thanks for letting me know I may well get it serviced before the end of the year just to be on the safe side....I suppose one good thing is that I've got both a 6 month dealer warranty and free 6 month AA warranty should anything go pop!!
