[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Urgent help required - UK-POLOS.NET - THE VW Polo Forum
this is the wrong section but i need help now so it'll get noticed here, it can get moved or whatever.
I just fitted my bmc and all was well when i started, but i revved it a couple of times and now my cars idling at 2000rpm
what the fook?
also, on here:
where mouse has connected his ducting to his original cold air feed on the right hand side of the original bit mine has a hose going to like the heat shield over the manifold, whats that hose for? it looks like his is taped up where it used to be
, I had the same problem on the lupo. same engine 1.4 AFK which uses the throttle cable. they replaced this in late 2000/2001 with the AUB engine which is drive-by-wire.
much perfer the cable throttle as you get no delay from pressing the pedal to getting the throttle response that you get in the early dwb engines!
btw i found out why the polo 16v bmc is more expensive than the gti, they are identicle except for some strange reason the 16v comes with a bmc crankcase breather filter
what i can't figure out is why it sometimes makes a roar and sometimes it doesnt, most the time it just sounds normal
occasionally when i drop it in to fourth and boot it i get a huge roar, which sounds totally amazing, but then when i do exactly the same thing again i get no roar really...it's strange
vdubit wrote:Sounds like your using the original intake pipe from the wing. Throw this away as its well restrictive.
This is true.
I found some decent piping at last, so finally got rid of my original intake pipe from the wing last night. Sounds about 10x better now, feels slightly better too
i still need to sort it out on mine.
no point in taking the original pipework out if you've just got a pipe stuck in the engine bay sucking in hot air.
