Well the aero "flat blade" wipers are on, as found by Tom, and they are excellent!
Also attacked the camber adjustment mission on sunday:
As you can see this is where you take the old bolt out, you also have to loosen the lower strut bolt to get it out!
This is a picture of the new bolt in the strut, there is a slight raised bump in the middle of the bolt, that allows the camber to adjust positive or negative to about 3 degrees. (Cambers not fully straight yet, its booked in thursday morning to get both wheels straight and flat.
Also purchased a set of Lupo GTi wheels today, that i'll be collecting this week sometime! and will look like the photoshop
