Exhaust system diameter - Manifold fitted! Vid Added 22/01
Tigz
Post by Tigz »
Spent a couple of hours on it last night, got the Alternator back on, and cut the stock system.
Not sure who's car this manifold was fitted to, or who had fitted it?
The pipe needs bending away from the sump, but also down wards as it rests on the sub frame.
The Oxyacetylene is buried in my mates van, and TBH we didn't fancy trying to get everything lined up correctly in the dark.
Plan is (on Sunday) remove the stock front section from behind the Cat', weld the flexi here and the rear section of the raceland pipe to the Cat pipe.
Then bend the manifold down pipe into shape.
Tried tonight with a scaffolding bar, but the engine mounts were taking most of the force!
olop_chris
Sponsor
Post by olop_chris »
Damn, my plan was to spend sunday wrapping the manifold up...but due to me entering my home postcode by mistake when i sent it to the work address, i've got to wait till saturday next week now!
Its annoying being an impatient person, isnt it!? :lol:
Tigz
Post by Tigz »
Tell me about it.
The car is up on ramps on the drive so Ive been using the wifes Saxo all week!
Tigz
Post by Tigz »
OK all fitted.
Had some serious issues to fit it right.
Before I fitted it, I wrapped the manifold. Id managed to wrap it in three sections.
When I fitted it and lined up the stock system it was clear it would fowl the sub frame.
So I had to cut the heat wrap at the bend so I could heat it and bend it.
I then stainless welded a stainless flexi an inch past the manifolds flexi mount.
This sits just under the sub frame.
After marking out the stock pipe, the Cat' was removed and the stainless welded to the Cat'
This way its nice and easy to remove if needed.
Much better than sleeving it IMO.
The wiring for the lambda probe was extended by metre (5 wires) by soldering and heat shrink on each section.
This was probably the most time consuming part!
I fed the cable up past the drive shaft, and following the existing wiring.
Need to get some more heat wrap, as theres a large section that was removed, and its tappy around the flexi section.
Really pleased with it.
The sound is a lot more raw than standard, it wouldn't be for everyone.
Performance wise, I love it.
Second gear is ace, the speed it eats the revs, and you can really feel the cam change over now.
It feels like an old school turbo hot hatch!
The video posted was recorded tonight a +2 degrees C.
The clips of the car when stock were at +4 degrees C.
Both clips were taken on wet roads.
The car is on 16" rims, and has a lot of weight in the boot, so the time are there purely to show the difference between the stock race land manifold.
I know its not the most scientific test, but still.
Stock.
0 - 60mph 9.17 Seconds
20 - 80mph 18.11 Seconds
Race land.
0 - 60mph 9.10 Seconds
20 - 80mph 15.23
Stock Manifold Vs Raceland Manifold
Si_GTi
Moderator
Post by Si_GTi »
I think the sound is a great improvement - I want one!! :D
Is that your youngun spluttering a little on the Raceland 20-80 run or is it a by-product of the new manifold at that point in the rev range? :wink:
Well done mate :)
Tigz
Post by Tigz »
lol yes the wife goes to gym after work so I took her with me.
Really please with it.
ECU off to the chap from Club Polo after this month, so will see how much of an improvment that will be.
Dee-vub
Post by Dee-vub »
haha i heard the splutter also.
But here, hold on a sec. 0-60 in 9.23s???? Why so slow?? Book is 8.4 isnt it??
Tigz
Post by Tigz »
It was wet.
I have 16" wheels.
I have a boot full of audio.
I have a set of front and rear discs and pads (still lol) on the passenger footwell.
In otherwards its wet and heavy lol
Dee-vub
Post by Dee-vub »
AAAhhh, understandable then isnt it. Sounds real good tho!!
olop_chris
Sponsor
Nice one Tigz.
Gotta love the Raceland :)
Tigz
Post by Tigz »
I know now how they can be made so cheap.
The stainless is very thin so sounds a little rastpy.
Great if like me, you like that sound.
But anyone who likes an OE sound I could imagen it could be annoying.
hedgehogharvey
Post by hedgehogharvey »
lol is that a baby coughing in the back ground at one stage.
Sounds good real improvement. cant wait to see the results after the ecu remap
cjwardy
Post by cjwardy »
Great work on the manifold mate, hat off to you.
Are you going to the club polo RR day by any chance?
Tigz
Post by Tigz »
cjwardy wrote:Great work on the manifold mate, hat off to you.
Ooh I wasn't aware of one.
Will take a look and may come down for the crack if its localish.
Reason I took the vid rather than rolling roads were I trust how the rev counter looks more than an unaccrate rolling road.
Wouldn't mind hearing the car on full felt though :D
dubpilot
Post by dubpilot »
olop_chris wrote:The only picture i could find...
Cant see it all that well, but its different to yours.
sorry to hijack, but does anyone know if the strut braces for the gti will fit lower models? e.g. 1.4 8v?
