[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Si_GTi's winter progress thread - Page 4 - UK-POLOS.NET - THE VW Polo Forum
I had no problems with scraping so far and I use the multistorey a lot. The pic below shows exactly where the lower strut brace goes. You can see why they have to remove the protective cover from underneath
(This may of been where my car got wet where it shouldn't have when cleaning the arches, that is if it definately turns out to be my fault in the end)
Mouse_GTI wrote:(This may of been where my car got wet where it shouldn't have when cleaning the arches, that is if it definately turns out to be my fault in the end)
Have they said it may be your fault?
No but I'm guessing a 50/50 chance (50 because I did get water close to the engine, 50 not because it drove fine for 20 minutes after)
I've chatted with a couple of people about it but otherwise yeah, kept it quite quiet - obviously once the lights are tinted and fitted I'll post the pics and talk a bit more about it then!
