[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 TDI Engine Oil - UK-POLOS.NET - THE VW Polo Forum
Just by looking at it, The cam cover is wider compared to the older mechanical pump tdi's, and there are no visible fuel injectors. In the polos all tdi's are of the PD variety.. hth
Dont go back to that dealer. I cant believe he told you that. The special oil used in pd diesels is due to the shear loads put onto the cam by the fuel injectors..
The 505 00 spec is for the older type TDis only.. the specs 505 01 and 506 01 (longlife servicing) must be used in the PD engines. It would probably damage the cam and pump injectors.. which aint cheap..
I have been topping up with the SLX III I was given by the dealership - so the guy at Halfords sold me Edge saying its the one I need, and it replaces SLX II.
I have still got the receipt, but have had the oil for 2/3 weeks. Hopefully they'll take it back or exchange for wipers
