The old 1.4 fsi engine is out now, im looking to sell it with ecu, gearbox etc, anyone know how much i could get for it? its got 45,000 & Full Vdub history.
Heres the rundown of parts i needed for my 280hp (hopefully) polo:
AYP 1.8t from Seat ibiza
02J Gearbox from Ibiza 5speed
Drive shafts from new skoda fabia TDI
K04-023 turbo, Manifold & pressure Pipe from Audi TT 225.
Custom Intercooler & Turbo inlet pipes
Injectors, 4bar FPR & fuel pump from Audi TT 225
3" MAF housing
Engine Mounts, Gearbox Mounts (OEM from VW)
Engine Support Brackets & console (OEM from VW)
Turbo Oil lines extended to fit because of K04
Front Mount Intercooler - 530 x 234 x 65 mm
Blitz Super sound BOV
3" Blueflame Custom D/P & Exhaust - from Turbo to Back
LINK G3 Stand Alone ECU & display link.
I was originally getting a plug and play ecu, but after ordering I was told its not quite plug n play on the 9N! The engine would run fine but all the tachos in the dash wouldn't & i would have to either get a polo GTI EMS or new LCR EMS or run extra gauges. I wanted a clean standard looking install & didnt want to change my dash, this was a big problem because the only reason I was doing the conversion was because it seemed easy (wrong!).
Then I was really regretting not taking the clocks, keys, ign barrel, ecu, etc from the donor car and I guess alot of people will think I should have gone that route in the first place, but now I am getting a stand alone ecu which can control everything (except VAG diagnostics), I found Thor racing who said they can help me out, The ECU will hook up to everything in the car so I dont have to change any clocks & it comes with a display link (small screen) which tells you everything.
I managed to grab a bargain off ebay for the K04 turbo & manifold last week (£285 & in excellent cond) so I had to get that which ment also getting a few extra bits like the fpr, maf etc.
Im waiting for my parts from VW, should be here on tuesday, then i can get the engine in place!
Then I Will be getting the car towed to BlueFlame for my Exhaust then to THOR Racing to get the ECU fitted & a day on the rollers mapping. Hoping to see 290hp, but i'll be happy with 250 to be honest!
All in the project is costing me £4250... if everything works I saved £3000 rather than paying another company & I have a standalone ecu.
Will be adding photos soon....watch this space!
Thanks for reading... any opinions much appreciated!
[/img]
