The bung has a hole in it for you to feed wires through.
As you look at your engine bay its on the RHS above the gearbox, in between the suspension strut and engine
Got it through in the end! problem solved...apart from i broke the fuse in the process so just jammed the power lead together with some tape....nice and dangerous!
