brakes
jj_2388
brakes
Post by jj_2388 »
hi, am considering uprating my brakes and was wandering what peoples views are? also best with aftermarket discs and pads or a full upgrade ie off another vehicle? cheers JJ
Dee-vub
Re: brakes
Post by Dee-vub »
jj_2388 wrote:hi, am considering uprating my brakes and was wandering what peoples views are? also best with aftermarket discs and pads or a full upgrade ie off another vehicle? cheers JJ
280mm G60 brakes are a popular upgrade
But i think a set up like 256 zimmerman grooved and drilled discs, a decent set of pads, and upgraded braided hoses would do the job perfectly well
jj_2388
Post by jj_2388 »
for the g60 conversion, what do you all need? callipers, carriers, discs and pads? also is there any upgrade for the rear?
cheers
SteveB
Post by SteveB »
jj_2388, what size disc's do you have standard?
On the 16v I've got 256mm, so for me to upgrade to g60 280mm all I need is the disc's and carriers. (Oh and of course 15" wheels, 14" are too small)
jj_2388
Post by jj_2388 »
think its 256mm, no to sure, just standard gti. so you dont need callipers or that?
cheers
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
To upgrade a GTi to 280mm, all you need are:
New 280mm discs (Golf G60 4-Stud),
Caliper Carriers,
New pads if you can afford them,
That's it.
jj_2388
Post by jj_2388 »
thanks, is there a big diference in braking? and just leave the rear standard?
cheers
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
In terms of rear braking, they do so little anyway there isn't much point in upgrading them. Personally I just fitted new standard pads as the originals were worn down.
As for the difference doing it makes, it's all relative I guess. I only fitted standard OEM discs and pads so in terms of actual stopping power there's no real gain. Aftermarket discs and pads should make a bigger difference.
However the real advantage from the 280mm conversion is resistance to brake fade. Across my favourite moors road whereas the 256mm were useless by the end, the 280s are still rock solid.
