Hello
I'm on the look for some g60 carriers, a set of VR6 carriers, discs and pads (all brand new) have popped up at the back of a mates garage - he says i can have them basically.
What i wanted to try find out is - are they going to fit the polo (poss the same as the g60 ones ?)
Anyone any ideas ?
VR6 Brakes ?
RICHARD HARPER
Can't you just measure disc diameter with tape measure or something ?
And another thing if there 5 stud discs, you'll no there no good without adaptors as there off later model
Or re-drilled holes (But may work out cheaper getting the 4 stud 280mm discs from a local motor factors)
But i'd think the carriers might still be ok....
Plus another thing what size of wheels you running ?
As for 280mm discs i think you'll need wheels of 15" and above
Good luck
Good luck
