[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Gearbox Rebuild - Can you uprate ? - UK-POLOS.NET - THE VW Polo Forum
i'm on 62k and the diff is making some beautiful noises! i've been thinking of uprated internals but all i have found so far is a dog box gearset and slippy diff. i'm not too keen on the gearset in a daily but would it be worth getting a lsd?
ive had my car for over a year now and its coming up to 60k, havent noticed any problems with the box but this whole whining noise bothers me, dont cars always make some sort of whining noise when driving? i get it in 1st and 2nd but i assume thats because its a high gear, nothing like the sound you get in reverse though
Mouse_GTI wrote:Does changing gearbox oil help prevent wear? If so how do you do it and what stuff do you use?
I had the gearbox oil changed in mine twice in the 50k I owned it, the gearbox still went after I sold it. My understanding is the main weak spot is the 5th gear bearing as its plastic !! and the diff. I'm sure it should be easy enough to source a bearing the same size however made of metal, not sure on the diff though however the box is a really old design so not sure if maybe uprated diffs for the G40 would fit in it.
