1.0L to 1.4 16V, help please!!!!!
im looking to do a 1.4 16V swap from my current 1.0l im going to do the brakes at the time an wanted to know whether its a strate swap. im going to get awesome gti to sort out the ecu.
can i use the same driveshafts?
can i use the same suspenshion?
will it go on the same mounts?
I haven't done this (or any, rather) conversion, but I'd say the mounting points are the same. The suspension should be fine, even though the 16v has different shocks (gas filled) and different springs (shorter?). Your current car does not have an ARB I believe, so you could look into fitting that too while you're at it.
The driveshafts are part of the gearbox (well, sort of) so it depends on the box you're getting - if it's from the 16v then just use that box and driveshafts. They should bolt up to the hubs no problem.
1.0L to 16V conversion
the 1.4 16v conversion is fine but why dont you try a VR6 conversion or a 20VT both units are much mor tunable for the future if you plan on keeping your car for a few years
Theres a definate skill to driving a car with that much power.
A big engine like that will encourage oversteer, but not quite to the extent some people claim. is £6000 including the engine and VAT? if so i dont think you gonna get it much cheaper. Also Dubsport are the Dons when it comes to sqeezing VR6s in - just think "B16 DUB"
Dubsort recomended me to fit the 1.8T unit as it is lighter than the VR6 unit and more tunable, the downside is that if you use a golf GTI gearbox it doesnt come with an LSD fitted as standard so there may be wheelspin in 1st and 2nd gear when caned however once you hit third and get full traction it will blow most things away.
For quotes try Awesome GTi (0161 776 0777) in Warrington they wont touch the 1.8T conversion but may be able to do the VR6 conversion for you.
Another one to try is Golfnutz in northwich 01606 44369 I think theyve done a VR6 conversion
Or try only VW motorsport in Blackburn (01254 697 988) these guys know thier polos inside out and have been really helpfull with my car.
im going for a G60 had a quote of £600 to fit and get working well, dosent include the engine so do you know where i can get one??? its so cheap because its going to take a month!
but its going to save me sooooooooooo much money
sould be a beast
i've been looking at Hi-spec brakes and havent found any kits as of yet (dont think they make any!!!) but i have found an interesting kit.
will fit MK1 and 2 golfs. 285mm disks and 4 pot calipers and all mountings. big question is weather the MK1 and 2 golfs where 4stud? will the calipers hangers fit or will i have to get new ones made.
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
MovIt make a big brake kit, and I'm pretty sure there are others out there. Go here: http://www.movit.de/rahmen/vw.htmdubpolo wrote: i've been looking at Hi-spec brakes and havent found any kits as of yet (dont think they make any!!!) but i have found an interesting kit.
Mk1 and 2 Golfs were in fact 4 stud, but if the brakes simply bolt up I can't say.
If there's 'only' 160 horses on tap, you may get away with fitting the Mk5 GTI brakes which are already (much?) bigger than what you have now. Alternatively, get the stock G60 brakes and fit those.
Good luck with the conversion I was thnking about a G40 engine in my polo but it was meant to have massive reliability problems I'm not sure if this is the case with the G60 Engine, but the conversion will be releatvely easy.
I last saw A G60 Engine for sale on the Awesome GTi website. It was from a Corrado and was about a grand. Not sure if its still there though.
