[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 VAG-COM - UK-POLOS.NET - THE VW Polo Forum
Can I add cruise control to my car? I know I need a new stalk and to 'switch' it on, but will I need additional wiring and will the light on the dash work?
Also I think VAG-COM can program the low washer fluid light to come on from what I understand.
You can turn on the crise control funtion, but fitting it to the polo will be as hard as it is to the fabia, which is why no-one on briskoda that diddnot have it fitted at tthe factory has it yet (me included). It is not worth trying to turn on the low level light as if the washer bottles capacity was big enough it would already have the sensor and function alredy enabled.
What makes it hard? Is it the removal of the steering wheel? DBW cars should have the wiring I think.. Well from what I understand.
I will give the low washer light a go, I have the winter pack so maybe its there IE the 5 litre capacity bigger bottle? Hope so anyway, if it’s not then.. damn!
it's the fitting of the wiring due to space IIRC. everything else is fairly simple. Any drilling holes voids the warrenty, even if it is done by a dealer so that is what they are trying to get around at the moment.
