Can someone tell me how to replace the coolant in my GTi. I know where the reservoir is but i have no idea how to drain it and replace the coolant.
Cheers,
Dan
Coolant replacing
Well make sure its cold for a start, dont come home and think i'll do the job as the water will be hot!
Basicly all you should have to do is unplug a pipe from the radiator and let it drain out, then refill with colant and water and bob's your uncle,
Dont take this as Gospile and either read a haynes manual or get a mech to do it.
The above ways work fine but if u want 2 be rearly clever u can buy an adapter from snap on that will screw into the expansion bottle were the cap normaly sits then u can plug a hose pipe into it, then with the bottom hose pipe off u can leave it for 20mins or so and it will completley flush the coolant system out (u will be amazed how much s**t comes out)
This is what i do at work (vw dealer)
olop_chris
- Sponsor
