I have noticed that my rear windscreen washer has stopped working.
It appears to be leaking from the boot lid when I try to use the rear washer so I am assuming it has come undone from the rear wiper.
What makes things worse is that the water is messing around with the electrics in the boot and making the car think that the boot is open when it isn't. This is causing the alarm to go off when the car is parked as it thinks someone has broken into the boot
Can anyone give me advice on how to remove the plastic cover from the boot lid and also the plastic cover at the front of the boot (opposite the back of the seats) so that I can try and fix the problem.
Any help would be much appreciated!!!
