Rear Windscreen Washer Problems With a Twist :)
TheEggShell
Post by TheEggShell »
Hi all,
I have noticed that my rear windscreen washer has stopped working.
It appears to be leaking from the boot lid when I try to use the rear washer so I am assuming it has come undone from the rear wiper.
What makes things worse is that the water is messing around with the electrics in the boot and making the car think that the boot is open when it isn't. This is causing the alarm to go off when the car is parked as it thinks someone has broken into the boot :roll:
Can anyone give me advice on how to remove the plastic cover from the boot lid and also the plastic cover at the front of the boot (opposite the back of the seats) so that I can try and fix the problem.
Any help would be much appreciated!!!
Mouse_GTI
Post by Mouse_GTI »
I remember the first time it happened with me it was causing my alarm to randomly go off. Second time it happened (last month) it was just the boot light. I pulled out the switch, cleaned it and it has been fine ever since
neilGTI
Post by neilGTI »
Are the boot plastics easy to take off ?
I have something rattling around in there when i go round corners, so i could do with taking mine off.
Is it just a case of undoing the two screws and then giving it a good pull ?
I will be checking the washer pipe is secure whilst i am in there as well
one_must_fall
Post by one_must_fall »
Its very easy. Just two screws and some clips. Haynes manual will help.
Mouse_GTI
Post by Mouse_GTI »
Remember the screws. I remember getting in a rage as it wouldn't come off with all the clips undone....then I saw the 2 screws *doh*. I've superglued my washer pipe to the connector now, seems to work better than a cable tie
one_must_fall
I've used a jubilee clip...
Post by 8080 »
You need to pull the panel out at the "glass" edge. Work in from one side, pulling the panel perpendicular to the door. There's about 6 clips to pop out at the glass edge. Then the panel will come away from the door.
There's 4 tabs at the bottom edge of the boot door that are very easy to break during this job. But they're easy to glue back on too :)
Tim_GTi
Post Whore
Post by Tim_GTi »
Two torx screws in the handles recess', carefully unclip and pull away the palstic casing, jobs a good 'n
neilGTI
Post by neilGTI »
I found out what my rattling noise was, and it wasnt in the boot lid, it was a couple of huge gobstoppers in the spare wheel well :? :o :lol:
I might still take off my plastics just to check that the rear pipe is firmly attached if its as easy as you guys are making out.
Tim_GTi
Post Whore
Post by Tim_GTi »
Actual Gobstoppers?
neilGTI
Post by neilGTI »
Tim_GTi wrote:Actual Gobstoppers?
yeah :? i dont know how they would have gotten in there ?
There were also 2 wine gums and 10pence under the back seats :lol:
Tim_GTi
Post Whore
Post by Tim_GTi »
lol, are you an avid sweet fan or something?
neilGTI
Post by neilGTI »
Not me, the previous owner i presume.
I have only had the car for 3 days and i wouldnt dream of eating in it as it is pristine inside.
Where the sweets came from and how they got into these strange places is a mystery :mrgreen:
Tim_GTi
Post Whore
Post by Tim_GTi »
haha!
Yeh i have a no eating and smoking policy in my car too, although I was cleaning mine the other week and found a chewing gum mess sutck to one of the rear mats, not happy!!! doubt it will come out either
TheEggShell
Many thanks for the help folks!
All sorted now :lol:
