Camber
It has been said that there are special shim packs available that allow you to get slight adjustment by fitting wedged shim packs behind the hub mounting plate. Have a look on briskoda.net as someone, maybe basil , tried this out to correct an alignment problem - yes you are correct for all normal people there is no adjustment other than moving the front around.
shanethb
Yes whiteline make one. Part number KCA310. I can get whiteline cheap here and may be able to send some over if anyone needs.
http://www.whitelineautomotive.com/Bull ... 8_Shim.pdf
