Camber
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Camber
Post by loud »
Do the 9Ns have adjustable rear camber or are they like the 6Ns where only the front camber is adjustable?
loud
Post by loud »
i meant camber and tracking
loud
Post by loud »
well i fired on and no the rear doesn't have camber or tracking :lol:
It has been said that there are special shim packs available that allow you to get slight adjustment by fitting wedged shim packs behind the hub mounting plate. Have a look on briskoda.net as someone, maybe basil , tried this out to correct an alignment problem - yes you are correct for all normal people there is no adjustment other than moving the front around.
shanethb
Post by shanethb »
Yes whiteline make one. Part number KCA310. I can get whiteline cheap here and may be able to send some over if anyone needs.
http://www.whitelineautomotive.com/Bull ... 8_Shim.pdf
flyfs6
Post by flyfs6 »
Hey Shane, can you find out how much they'd be sent over to the UK please?
Many thanks.
shanethb
Post by shanethb »
No problem mate, may take till monday as its friday night now. Ill let you know.
Could You pm me an address so i can make sure i get the shipping right.
