black grille badge
loud
- Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
black grille badge
do these exist for the gti? or do you have to get one sprayed yourself
- KennyPOLO_Gti
- Platinum Member
- whitegtipolo
- KennyPOLO_Gti
- Platinum Member
- KennyPOLO_Gti
- Platinum Member
- whitegtipolo
- Tim_GTi
- Post Whore
If its anything like the mark5 badge. You just:
Remove the badge with a hairdryer and pulling it
Remove the glue points on the back of the badge using something like a stanley knife.
The front will then seperate from the back.
Spray back of the badge
Re-attach front and back using a glue gun
re-attach badge to car using trim repair from Halfords
This is mine. Sorry not the best pic.
I took the badge out then covered it with matt black vinyl. Pulling it tight so there are no bubbles.
I used vinyl because its cost $10 for a square meter so thats about 4 squid for you Poms. If I didn't like it I could just peal it off and have the chrome back again. Where if you paint it your stuck with it.
The rear badge is another matter
