They are going to look absolutely s**t hot though once you get them on properly and lowered man
Alfa Romeo 15" Rims
Well all i need is the rings tbh and I can get them custom made from a dealer on ebay for about £20 so its ok in terms of that.
I fitted the wheels on the front last ngiht too just to check the Centrebore. I took the little alfa centre cap off to look and they fit with 1mm to spare as i thought. So just need the wobbly bolts and my new suspension which I am going to order on Monday so I'll have my Coilies and wheels hopefully all will be fitted next saturday or so, weather pending
You defo need the spigott rings or you could have a serious accident mate as you know what happened to mine. The centrebore takes some weight off the nuts you see, if its not sitting on the hub then all the weights on the nuts, which could break.
Any tyres/alloys centre will be able to sort you out. Its usually black plastic and sits in between the centre hole of the rim and CB ring of you hubs.
Just get 4 rings and the wobbly nuts and your
mate!
Thanks for the info Noz. I'll keep you guys postedNOZ wrote:You defo need the spigott rings or you could have a serious accident mate as you know what happened to mine. The centrebore takes some weight off the nuts you see, if its not sitting on the hub then all the weights on the nuts, which could break.
Just get 4 rings and the wobbly nuts and yourmate!
Josh_polo
I would but i cant any anywhere nt even on ebayiggy350 wrote:hehe cool I started a mini trend yay me =D you should m8 they look mint, Im considering getting them refurbed and painted white with black inlines in the circlesJosh_polo wrote:Since seeing this ive seen a set in a breakers....but one is missingwell want set now though
I'll keep my eye out on ebay for u m8. I'm on there most days at work...while im not doing work but never the less lol I get paid to browse ebay heheJosh_polo wrote:I would but i cant any anywhere nt even on ebayiggy350 wrote:hehe cool I started a mini trend yay me =D you should m8 they look mint, Im considering getting them refurbed and painted white with black inlines in the circlesJosh_polo wrote:Since seeing this ive seen a set in a breakers....but one is missingwell want set now though
lol ok then, but what are a set of desent sized tyres for the 15s then? cos atm they got some big ass ones which are all cracked so i need new for it so ill get some put on, on thursday or fridayJosh_polo wrote:iggy350 wrote: So I got coilies question is how low do i let the polo go?
Dont ever ask that again!!!
Drop it on its arse!
That also depends on how low you wanna go. if they're 7-7.5J width then you'll need 195/45/15's. If you plan on going very low which'll cause scrubbage then you need to find a thinner profile or get some stretch. For example getting stretch will reduce the 195 and thinner profile will reduce the 45.
How low you wanna go depends on personal situation. However, go as low as possible and maybe a bit further!
frankiepolo
