Alfa Romeo 15" Rims
LeMeph
Post by LeMeph »
yeh i have no idea whered youd go for apigot ring to fit them.
They are going to look absolutely s**t hot though once you get them on properly and lowered man 8)
iggy350
Post by iggy350 »
Well all i need is the rings tbh and I can get them custom made from a dealer on ebay for about £20 so its ok in terms of that.
I fitted the wheels on the front last ngiht too just to check the Centrebore. I took the little alfa centre cap off to look and they fit with 1mm to spare as i thought. So just need the wobbly bolts and my new suspension which I am going to order on Monday so I'll have my Coilies and wheels hopefully all will be fitted next saturday or so, weather pending :)
NOZ
Post by NOZ »
You defo need the spigott rings or you could have a serious accident mate as you know what happened to mine. The centrebore takes some weight off the nuts you see, if its not sitting on the hub then all the weights on the nuts, which could break.
Any tyres/alloys centre will be able to sort you out. Its usually black plastic and sits in between the centre hole of the rim and CB ring of you hubs.
Just get 4 rings and the wobbly nuts and your 8) mate!
iggy350
Post by iggy350 »
NOZ wrote:You defo need the spigott rings or you could have a serious accident mate as you know what happened to mine. The centrebore takes some weight off the nuts you see, if its not sitting on the hub then all the weights on the nuts, which could break.
Thanks for the info Noz. I'll keep you guys posted
Josh_polo
Post by Josh_polo »
Since seeing this ive seen a set in a breakers....but one is missing :cry: well want set now though :lol: 8)
iggy350
Post by iggy350 »
Josh_polo wrote:Since seeing this ive seen a set in a breakers....but one is missing :cry: well want set now though :lol: 8)
hehe cool I started a mini trend yay me =D you should m8 they look mint, Im considering getting them refurbed and painted white with black inlines in the circles :)
Josh_polo
Post by Josh_polo »
I would but i cant any anywhere nt even on ebay :shock:
iggy350
Post by iggy350 »
I'll keep my eye out on ebay for u m8. I'm on there most days at work...while im not doing work but never the less lol I get paid to browse ebay hehe
Josh_polo
Post by Josh_polo »
Sweet nice one,you have a pm :wink:
iggy350
Post by iggy350 »
Ok peeps small update.
Wobbly bolts and Suspension is now ordered hehe. So I got coilies question is how low do i let the polo go?
Josh_polo
Post by Josh_polo »
iggy350 wrote: So I got coilies question is how low do i let the polo go?
:evil:
Dont ever ask that again!!!
Drop it on its arse! 8)
iggy350
Post by iggy350 »
:evil:
lol ok then, but what are a set of desent sized tyres for the 15s then? cos atm they got some big ass ones which are all cracked so i need new for it so ill get some put on, on thursday or friday
NOZ
Post by NOZ »
That also depends on how low you wanna go. if they're 7-7.5J width then you'll need 195/45/15's. If you plan on going very low which'll cause scrubbage then you need to find a thinner profile or get some stretch. For example getting stretch will reduce the 195 and thinner profile will reduce the 45.
How low you wanna go depends on personal situation. However, go as low as possible and maybe a bit further!
iggy350
Post by iggy350 »
well the wheel is only 6j and where I live its not that advisable to go really low. I was thinking like 50 to 70mm tops. Cos at the bottom of my road theres a killer speed bump :( I was hoping that 195/50s would be ok what you guys think? If need be I'll get the 45's tho
frankiepolo
Post by frankiepolo »
looks a bit mental. differant. fair play
