[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Strut Brace....Updated!!!!!!!!!! - UK-POLOS.NET - THE VW Polo Forum
Need help!!!!
Just fitted eibach pro-kit springs in my polo.....so just to finish off i want to get strut brace for the front........
So, i was wondering if it is possible to fit front strut brace to my polo which is a 1.2L E(55) and what make should i go for? I noticed in few posts on here that a seat ibiza cupra brace would fit on polo's.
Please advice...
panda wrote:I've got the seat sport on one mine (ibiza one) and it's great.
Get one, fit it yourself as it's pretty easy to do. But you may need 2 people.
Mate will it be possible for you to post a picture please also what is the part number for strut brace as i will need it when ordering from seat......
Have a look on either of the two Seat forums - someone posted a Seat link when I asked - or just ask the Seat dealer to order in a Seat Ibiza optional MOMO sport strut brace - the cost is £55 I believe. Other than that just go onto the Seat website and look for merchandising of something.
Which engine do you have? Just in case the lesser engines with the bigger airboxes cause a problem - oh and have the dashboard rattles quietened down a bit since you fitted it - maybe a picture pls if you have a large engine covering airbox!
How easy is it to fit an upper strut brace, just a case of un doin the three bolts on each side then puting the brace in place then put the bolts back in? How do you od it?
polospeed wrote:How easy is it to fit an upper strut brace, just a case of un doin the three bolts on each side then puting the brace in place then put the bolts back in? How do you od it?
No noises from behind the dashboard, strange!?! - it can't be a Fabia/Polo/Ibiza then as that was what was included to give these cars character!
Back to the original question, "did you need to remove the security cover from the engine's ECU" - or had it already been removed before you bought this car?
