Strut Brace....Updated!!!!!!!!!!
POLOZ
Post by POLOZ »
Hello,
Need help!!!! :)
Just fitted eibach pro-kit springs in my polo.....so just to finish off i want to get strut brace for the front........
So, i was wondering if it is possible to fit front strut brace to my polo which is a 1.2L E(55) and what make should i go for? I noticed in few posts on here that a seat ibiza cupra brace would fit on polo's.
Please advice...
panda
Post by panda »
I've got the seat sport on one mine (ibiza one) and it's great.
Get one, fit it yourself as it's pretty easy to do. But you may need 2 people.
POLOZ
Post by POLOZ »
panda wrote:I've got the seat sport on one mine (ibiza one) and it's great.
Mate will it be possible for you to post a picture please also what is the part number for strut brace as i will need it when ordering from seat......
Also will it fit my polo?
KJ
Have a look on either of the two Seat forums - someone posted a Seat link when I asked - or just ask the Seat dealer to order in a Seat Ibiza optional MOMO sport strut brace - the cost is £55 I believe. Other than that just go onto the Seat website and look for merchandising of something.
chewy
Post by chewy »
Part Number for the seat brace is 6L0071710 thet are around £55, just spoke to seat last week
Which engine do you have? Just in case the lesser engines with the bigger airboxes cause a problem - oh and have the dashboard rattles quietened down a bit since you fitted it - maybe a picture pls if you have a large engine covering airbox!
POLOZ
Post by POLOZ »
Thanks guys for the help.....
Ordered the brace today....so hopefully they will fit....
polospeed
Post by polospeed »
How easy is it to fit an upper strut brace, just a case of un doin the three bolts on each side then puting the brace in place then put the bolts back in? How do you od it?
K.I.T.T.
Drives: Bicycle
Post by K.I.T.T. »
polospeed wrote:How easy is it to fit an upper strut brace, just a case of un doin the three bolts on each side then puting the brace in place then put the bolts back in? How do you od it?
http://www.tigerstyle.co.uk/poloforum/v ... trut+brace
Although, on some strut braces you need to undo 3 bolts...the rest's the same.
Ash :)
POLOZ
Post by POLOZ »
well got the strut brace in today....and installed it in 5mins......
It seems to be quite a tight fit againt the seal and its actually touching the metal part on which the seal goes on....is this OKay?
polospeed
Post by polospeed »
How easy was it to fit poloz? going to order myself one on monday I think. Do you have to take the cover off the ecu?
POLOZ
Post by POLOZ »
polospeed wrote:How easy was it to fit poloz? going to order myself one on monday I think. Do you have to take the cover off the ecu?
quite easy to fit.....mate :D ....its a tight fit against the seal but i think it will work well......
polospeed wrote:Do you have to take the cover off the ecu?
Bump!
Also have you noticed a reduction in the dashboard noises?
POLOZ
Post by POLOZ »
Bump!
Well mate fortunately i havent experienced any dashboard noises since i bought the car... :)
No noises from behind the dashboard, strange!?! - it can't be a Fabia/Polo/Ibiza then as that was what was included to give these cars character!
Back to the original question, "did you need to remove the security cover from the engine's ECU" - or had it already been removed before you bought this car?
