Few problems with Dub rubbing. As much as i love my Cup's , they're a bit of a pain, with a ET of 28 wrapped in 195/45/15 Rubber i'm catching my outter arch, even more now i've had the tracking sorted. Only when i hit a bump though or uneven road surface. Any of you removed your arch lining's or rolled your arches due to this, its only on the front end as the rear sits a bit higher. (Will be lower soon, and with rear spaces)
Any help would be great.
Rob
Dub is Rubbing.
Same thing happened to me mate, what I've done is just raise the fronts, and when going to local meets or shows, the day before I'd deck it down again, or if I'm lazy not even bother. I was considering arch rolling but haven't really got any monies at the moment so I'm pretty much stuck with what I'm doing now.
The_phat_controlleruk
If you don't mind me asking, where did you get your arches done, I neeeeeeeeeeed to get mine done. I'm on 194/45/15's down 80mm and boy, does she scrub. How much did they charge you?scottyj12 wrote:ive had my arches done, still get a little bit of scrubbage but the arches are alot thinner and smoother now its been rolled etc.
Thanks alot.
- Tim_GTi
- Post Whore
To be honest mate, if it's just now and then I wouldn't worry about it.
I get it now and then also, and i just think it's re-assuring to know that you are at your lowest point without massive inconveniance.
If I didn't get scrubbing now and then I'd be back under those arches working out exactly how low I can actually go.
If it relaly does bother you though, get em rolled.
Yeh, what is there quality of work like? Any paint cracking?scottyj12 wrote:I got it done by Arch Enemy mate, came to me and done it! Was a great Job. Cost me £130 to do all four.
