007p psssst
titan619
007p psssst
Post by titan619 »
looking for a dump valve and heard the forge 007p is recomendable, it says on the forge website it is silient in operation, does this mean you cant hear the pssst when u release the gas or change gear.is there any dv that would give of a noticable sound
shanethb
Post by shanethb »
yeah i believe the forge spliter valve would give you more noise. Not having heard one just what ive read on there site.
Forge Motorsport
Post by Forge Motorsport »
We recommend the 007P for Polo applications, if you have an open intake i.e. not the stock airbox, then you will probably hear the 'pssshh' on gearchanges, but dont hold me to that. The Split-R works well on some cars and not on others, which is why i recommend the 007P above it.
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
I have my 007p fitted in reverse and it sounds great, you hear the psst more and also get the chirp from the piston slamming shut. You only really hear the chirp prior to remap but post remap you hear a lot more cool stuff :lol:
whitegtipolo
Post by whitegtipolo »
i have the splitter one for sale £80 8)
titan619
Post by titan619 »
thanks for the replies, any one know where you can get one and have it installed in london? how much are you looking to pay for the 007p and it being put in your ride
kc
Drives: an imaginary one... for now
Post by kc »
loud wrote:I have my 007p fitted in reverse and it sounds great, you hear the psst more and also get the chirp from the piston slamming shut. You only really hear the chirp prior to remap but post remap you hear a lot more cool stuff :lol:
i tried this the other day, and the chirp sounds like there is a small pig under my engine each time i lift off!! hahaha
Jeff GTi
Post by Jeff GTi »
how do you fit it in reverse, and what will the benifits be for doing so, if any?
kc
Post by kc »
just how it is jeff
the bit that returns goes to inlet, and vice versa
it didnt make any difference with perfomance, just noise - but only if you hvae open end filter on! hth
more-bhp
Post by more-bhp »
titan619 - they are so easy to fit yourself - the Polo GTI usually has reusable clips so no need for hunting for jubilees..
5 minute job for 007p
OZPOLOGTI
Post by OZPOLOGTI »
Sorry to hijack but does any one use the Yellow uprated spring for a chipped polo do you need to when running higher boost.
Cheers Rob.
more-bhp
Post by more-bhp »
Supplied/fitted spring is fine for stage 1 boost of 1.1-1.2 bar... like in the Polo.
Other Vag cars like some S3 1.8T and TT 225 run 1.5bar+ on stage 1 so can make use of a stronger spring.
I needed to sell my 007p to a customer so put the standard bosch item back.. still working fine even at 1.4/1.5 bar boost...
sometimes is a case of try it and see how it goes... after all it takes on seconds to swap the spring over.
J
whitegtipolo
the spring doesnt hold the valve shut, it determains how hard it is for the valve to open with vacuum , and how fast it shuts again, as equal boost is on each side of the piston on boost it cant open, read once a guy tested both racing spring and normal and showed no real gains or differences! If your that bothered dont bother with a new spring set slap a couple of washers in!
OZPOLOGTI
Post by OZPOLOGTI »
Thanks for that all good :) understand how it all works now.
Rob.
KennyPOLO_Gti
Post by KennyPOLO_Gti »
So ur runnin stage two with standard DV in Jason?? :?
