looking for a dump valve and heard the forge 007p is recomendable, it says on the forge website it is silient in operation, does this mean you cant hear the pssst when u release the gas or change gear.is there any dv that would give of a noticable sound
We recommend the 007P for Polo applications, if you have an open intake i.e. not the stock airbox, then you will probably hear the 'pssshh' on gearchanges, but dont hold me to that. The Split-R works well on some cars and not on others, which is why i recommend the 007P above it.
I have my 007p fitted in reverse and it sounds great, you hear the psst more and also get the chirp from the piston slamming shut. You only really hear the chirp prior to remap but post remap you hear a lot more cool stuff
thanks for the replies, any one know where you can get one and have it installed in london? how much are you looking to pay for the 007p and it being put in your ride
loud wrote:I have my 007p fitted in reverse and it sounds great, you hear the psst more and also get the chirp from the piston slamming shut. You only really hear the chirp prior to remap but post remap you hear a lot more cool stuff
i tried this the other day, and the chirp sounds like there is a small pig under my engine each time i lift off!! hahaha
the spring doesnt hold the valve shut, it determains how hard it is for the valve to open with vacuum , and how fast it shuts again, as equal boost is on each side of the piston on boost it cant open, read once a guy tested both racing spring and normal and showed no real gains or differences! If your that bothered dont bother with a new spring set slap a couple of washers in!
