Standard GTi Suspension! Is it lower than 1.4 16V 6n2?
6n-polo-valver
Post by 6n-polo-valver »
HI guys,
does ayone know if the standard GTi suspension is lower than the 6n2 1.4 16v suspension?
would shocks/springs from a 1.4 6n2 fit a 6n2 GTi?
thanks
alexperkins
Site Admin
Post by alexperkins »
Yes. GTI suspension is lower than all other models. Its all the same fitting...just different compression in the struts and shorter springs on the GTIs
Si_GTi
Moderator
Post by Si_GTi »
As above :)
I have a full set of standard GTi suspension in a box under the stairs doing 'nout, been there for 18 months as I have no need for them after fitting coilies!
6n-polo-valver
the legend speaks! :D
cheers alex!
p.s....would i inherit any problems using non gti suspension?
how much lower is it from the others?
Tim_GTi
Post Whore
Post by Tim_GTi »
It's around 15mm lower
tegwin
Post by tegwin »
If you use longer non GTI suspension you will knock the camber and tracking (Front and back) out of true...
The ARB might get over stressed and the car will look like something out of the whacky races
alexperkins
Site Admin
Tegwin holds a valid point. Its set up for lower suspension, so it really needs to be kept with struts that are the right length
CymruPolo
Not so new
Post by CymruPolo »
Tim_GTi wrote:It's around 15mm lower
But can still give you a nose bleed it's so high :lol:
Tim_GTi
Post Whore
Post by Tim_GTi »
Lol yeh you can. The 6N2 has a ridiculous standard height, the car came with a parachute as standard :lol:
CymruPolo
Not so new
Post by CymruPolo »
Ohh so that's what that thing under me seat is :lol:
Scott F
Post by Scott F »
CymruPolo wrote:Ohh so that's what that thing under me seat is :lol:
I heard that on the early models the parachute was just an optional extra until some owners experienced death while exiting their polo.
