[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 How to make the polo GTI brakes better? - UK-POLOS.NET - THE VW Polo Forum
changing to an uprated disc and pad may improve it marginally, but if you want any real improvement you'd probably have to go for a 4-pot setup like AP ones. That chap whos having the 1.8t conversion at the mo has them i think, theres a thread about somwhere!
braided pipes dont rearly make that much difference!
Best combo ive found has been standard disk's and ither green stuff or black dimond pads!
And a good bleed!
Grooved discs with uprated pads (I have Brembo items with Mintex Sport pads).....works well and also DOT5.1 brake fluid which has got rid of the spongy brakes when they are pushed hard and get hot.
Are you sure your standard system is set up correctly?
I have standard brakes that have been bled very carefully using a high pressure bleeding system...
And I have no issues with the brakes... Get a little bit of fade on very long twisty drives...but I never loose the sharpness... I loose traction first
What effect does fitting larger 4 pot callipers have on the functioning of the ABS I wonder
My pedal has to go more than halfway to get any meaningful breaking, and even then it is very poor and feels vague. ABS works as usual when the pedal is right down
