Posts: 14873 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Tue Oct 21, 2008 10:02 pm
As you all know, polo brakes are shocking...so what can you do to improve them?
So far I have a 280mm G60 conversion, which has made a slight bit of difference, but its running OEM discs and pads.
So...what can I change to make them better?
Alex
andyniceday
Posts: 126 Joined: Sun Feb 25, 2007 6:25 pm
Post
by andyniceday » Tue Oct 21, 2008 10:46 pm
changing to an uprated disc and pad may improve it marginally, but if you want any real improvement you'd probably have to go for a 4-pot setup like AP ones. That chap whos having the 1.8t conversion at the mo has them i think, theres a thread about somwhere!
Post
by alexperkins » Tue Oct 21, 2008 11:12 pm
I had a look earlier...I'm not that fussed to spend £550 on new brakes haha
Basically, I want to keep the same brake setup, but increase its efficiency
I have read that black diamond discs and pads offer uprated performance, but I never have tried them at all. Anyone?
Tim_GTi
Post Whore
Posts: 12289 Joined: Mon Jun 25, 2007 6:31 pm
Post
by Tim_GTi » Wed Oct 22, 2008 12:01 am
What about braided hoses? And drilled and grooved discs?
bbspolo
Posts: 634 Joined: Tue Dec 25, 2007 2:28 am
Post
by bbspolo » Wed Oct 22, 2008 12:31 am
braided pipes dont rearly make that much difference!
Best combo ive found has been standard disk's and ither green stuff or black dimond pads!
And a good bleed!
Mouse_GTI
Posts: 2937 Joined: Sat Apr 01, 2006 10:29 am
Post
by Mouse_GTI » Wed Oct 22, 2008 5:13 am
Mine have Black Diamond drilled and grooved discs and are still as s**t as ever
Mike_M
Posts: 133 Joined: Tue Aug 23, 2005 7:20 pm
Post
by Mike_M » Wed Oct 22, 2008 8:58 am
Grooved discs with uprated pads (I have Brembo items with Mintex Sport pads).....works well and also DOT5.1 brake fluid which has got rid of the spongy brakes when they are pushed hard and get hot.
On top of that, I would get braided hoses.
tegwin
Posts: 945 Joined: Mon Nov 13, 2006 5:14 pm
Post
by tegwin » Wed Oct 22, 2008 9:22 am
Are you sure your standard system is set up correctly?
I have standard brakes that have been bled very carefully using a high pressure bleeding system...
And I have no issues with the brakes... Get a little bit of fade on very long twisty drives...but I never loose the sharpness... I loose traction first
What effect does fitting larger 4 pot callipers have on the functioning of the ABS I wonder
Post
by alexperkins » Wed Oct 22, 2008 9:23 am
Well they are ok...but compare them to like a new polo and a golf they are rubbish!
tegwin
Post
by tegwin » Wed Oct 22, 2008 9:40 am
alexperkins wrote: Well they are ok...but compare them to like a new polo and a golf they are rubbish!
Aye...Point taken...
you deffinately have to press on the brakes to make the work.... I quite like that though... its a more in-touch feeling lol
Post
by alexperkins » Wed Oct 22, 2008 9:52 am
I guess that in it self is a good thing....but you can push your foot to the floor, and it wont stop!
1der
Posts: 604 Joined: Fri Aug 11, 2006 2:41 pm
Post
by 1der » Wed Oct 22, 2008 10:21 am
ive driven a 1.4 astra that braked better tha the gti
ive got black diamond predator pads and standard discs, but they are still poor
tegwin
Post
by tegwin » Wed Oct 22, 2008 10:34 am
alexperkins wrote: I guess that in it self is a good thing....but you can push your foot to the floor, and it wont stop!
Thats worrying...sound like you have a problem with the standard setup...
From 100 I can slam on the brakes so hard that the ABS kicks in almost imediatly...Wouldnt want to do that too often though
Mouse_GTI
Post
by Mouse_GTI » Wed Oct 22, 2008 11:55 am
My pedal has to go more than halfway to get any meaningful breaking, and even then it is very poor and feels vague. ABS works as usual when the pedal is right down
Tim_GTi
Post Whore
Post
by Tim_GTi » Wed Oct 22, 2008 11:58 am
In all fairness I've never really had a problem with the brakes. I dunno whether it's because mine aren't that bad, or I've just gotten used to them.
But surely a good bleed, grilled and groove uprated discs, uprated pads, better fluid and braided hoses would make some sort of difference!
