I think around 2500miles. A slight braking can trigger the noise. There were no noises when I got them fitted, since March. I only noticed the noise this week.
on low speed braking, i get a small squeek/squeel sometimes due to the pads being high carbon items (tarox pads) but its only then, not under firm or eavy braking
by the way, im 312 mm converted, using golf 4 anni calipers and carriers, goodridge braided hoses, tarox sport japan disks which are cross drilled and grooved and the tarox strada fast road pads
Jeff GTi wrote:by the way, im 312 mm converted, using golf 4 anni calipers and carriers, goodridge braided hoses, tarox sport japan disks which are cross drilled and grooved and the tarox strada fast road pads
is that all?
have a good look around them for anything that looks out of place etc..
sagaris wrote:I think around 2500miles. A slight braking can trigger the noise. There were no noises when I got them fitted, since March. I only noticed the noise this week.
Thats very very low mileage - you will have rusted up brakes due to lack of use - are both sides of all the discs still smooth and shiny?
Maybe also check for a trapped stone somewhere in one of the four assemblies - though normally they make horendeous noises - like everything breaking up.
just another thought if it isnt the dust cover. with having drilled and grooved discs the pads when aplied are going over the grooved and drilled bit and sometimes they make a light flicking noise. ive had this a few times with impreza owners doing big brake upgrades and drilled/grooved discs with performance pads. just my opinion
