Braking noise
sagaris
Braking noise
Post by sagaris »
I have a slight issue when braking. There's some kind of flickering noise. Anyone have an idea of what it could be?
KennyPOLO_Gti
Post by KennyPOLO_Gti »
How many miles have u done with ur discs and pads? Are u braking hard when u feel it??
sagaris
Post by sagaris »
I think around 2500miles. A slight braking can trigger the noise. There were no noises when I got them fitted, since March. I only noticed the noise this week.
KennyPOLO_Gti
Is it from both sides? Maybe somethin came loose, have u had a check?
sagaris
Post by sagaris »
I think its coming from the front left. I had a look, but I've no idea what I'm looking for.
Jeff GTi
Post by Jeff GTi »
on low speed braking, i get a small squeek/squeel sometimes due to the pads being high carbon items (tarox pads) but its only then, not under firm or eavy braking
by the way, im 312 mm converted, using golf 4 anni calipers and carriers, goodridge braided hoses, tarox sport japan disks which are cross drilled and grooved and the tarox strada fast road pads
pip_polo
Post by pip_polo »
Jeff GTi wrote:by the way, im 312 mm converted, using golf 4 anni calipers and carriers, goodridge braided hoses, tarox sport japan disks which are cross drilled and grooved and the tarox strada fast road pads
is that all? :lol:
have a good look around them for anything that looks out of place etc..
KennyPOLO_Gti
Or go back to guy that changed them :roll:
sagaris wrote:I think around 2500miles. A slight braking can trigger the noise. There were no noises when I got them fitted, since March. I only noticed the noise this week.
Thats very very low mileage - you will have rusted up brakes due to lack of use - are both sides of all the discs still smooth and shiny?
Maybe also check for a trapped stone somewhere in one of the four assemblies - though normally they make horendeous noises - like everything breaking up.
sagaris
Post by sagaris »
Disc aren't shiny, but not rusty. I use ma car everyday.
Jeff GTi, my setup is pretty similar to yours, except am using black diamonds.
I hadn't heard anything like this before. Its kinda like riding a bike with those plastic thing you put on the bar, so it taps the spokes.
Jeff GTi
Post by Jeff GTi »
in that case it will most likely be the dust cover has been mis shaped or damaged on the new brake fitting
the father in law had this on his rover 220 gsi after having new brakes, just needed re bending in to shape
young dubber
Post by young dubber »
just another thought if it isnt the dust cover. with having drilled and grooved discs the pads when aplied are going over the grooved and drilled bit and sometimes they make a light flicking noise. ive had this a few times with impreza owners doing big brake upgrades and drilled/grooved discs with performance pads. just my opinion
Jeff GTi
Post by Jeff GTi »
mine fan being cross drilled and grooved, but its more like a jumbo jet taking off than a pinking noise
