Please can anyone tell me anything about this fault
VAG-COM Version: Release 311.2-N
Control Module Part Number: 036 906 033 A
Component and/or Version: 1.6l/4V SIMOS3 00HS3148
Software Coding: 00031
Work Shop Code: WSC 00788
1 Fault Found:
17927 - Camshaft Adjustment: Bank 1: Malfunction
P1519 - 35-10 - - - Intermittent
VAG COM fault please help
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
Re: VAG COM fault please help
Might be a faulty cam position sensor...
Hopefully nothing more serious than that.
camshaft sensor mate like josh said!
they play up from time 2 time! delete the fault code and reset the readness codes and chances are it wont reapear!
If it does your can scope the camshaft sensor 2 check its operation and replace if nessary!
- Josh_PoloGTi
Now that I've had chance to think about it, I had this fault once on my GTi...
I was on my way to work one morning and the Check Engine light came on and the car went into limp mode.
I turned the engine off and on again and the car ran fine. Deleted the fault code when I got home and it never happened again.
Josh
Josh
yer its vey common the sensor gets a voltage spike and it sets the fault code off!
just rember 2 restet the readness code's
- ticki
- Sponsor
I got this fault again. can anyone tell me where/which exactly is the camshaft sensor thanks
- ticki
- Sponsor
well there is 2 sensors on the rocker cover, and ive always wondered which was indeed responsible for this error code
1 Fault Found:
I found this might be helpful
1. Fuel Injector
2. Hall Sender (sometimes call CIS- Cylinder Indentifyer Sensor, or Cam Position Sensor)
3. Throttle Body, contains throttle postision sender, idle switch + more
4. Coilpack- sometimes called DIS or distributorless ignition system
5. EGR Valve Actuator Solenoid, the actuall valve is underneath on the exhaust manifold
6. Thermostat Housing
7. Wiring Plug for Lambda Probe
8. -Underneath Hose- Wiring plug for Knock sensor
9. wiring plug for Speed Sender- sometimes called CAS or Crank Angle Sensor
10. Coolant Temperature Sensor - or CTS
11. Oil Pressure Switch
12. Fuel Rail
1 Fault Found:
1. Fuel Injector
12. Fuel Rail
