Headlamp washers
mazellann
Headlamp washers
Post by mazellann »
The headlamp washers have just stopped working on my GTI, i've checked the fuse and thats ok, can anyone give me any ideas on what else to check
cheers
Rossco
Re: Headlamp washers
Post by Rossco »
Mine tend to stop working when the fluid level is low??
Failing that, check the pipes on the rear of the jets, or the connections.
Trottagti
Post by Trottagti »
Yeah mine have packed up aswell as my horn, any advice would help!
mazellann
Post by mazellann »
feel a bit stupid now! put some water in and they work, thanks Rossco!
Obviously theres a sensor in the fluid resevoir so only the windscreen washers work when the water is low.
thanks again
alexperkins
Site Admin
Post by alexperkins »
Trottagti wrote:Yeah mine have packed up aswell as my horn, any advice would help!
Headlight washer pump has probably died
EDIT: Just found out some info. The fuse for the Horns is also for the Headlight Washers!! Yellow 20amp :D
Tim_GTi
Post Whore
Post by Tim_GTi »
If you've got less than 1litre in your fluid reservoir, the washers won't work.
